Re: sticky clutch solution?
Posted by Owen Aaland on November 10, 2008 at 09:44:29 from (65.161.86.88):
In Reply to: sticky clutch solution? posted by sgtbull on November 10, 2008 at 08:58:36:
There is a grease zerk for greasing the pilot bearing located in the flywheel. Turn the engine until the line on the front pulley that is not TDC or advance is under the pointer. There is a hole about an inch in diameter in the bottom of the clutch housing under the flywheel to allow access to the grease zerk.
