Another thought and part #s
Posted by ScottyHOMEy on November 10, 2008 at 15:30:46 from (70.105.230.210):
In Reply to: Re: carb settings posted by ScottyHOMEy on November 10, 2008 at 14:50:12:
My parts book is a reprint, but the rod and springs are on p. 79 in mine as chassis parts.
You said your A was a '39, so that rear spring MAY not be an issue. My book shows the rear spring only for serial numbers 2690 and up. If yours is earlier than that, we may have to look for another answer.
That said, the numbers for the springs, if they help your parts guy look them up are
53393D (rear)
51300D (front)
If you do wind up replacing them, it wouldn't hurt to recheck the synch between the arm and throttle rod on the left side as you did before.
