Re: M idles poorly
Posted by Dr. Bert on November 11, 2008 at 19:42:59 from (72.36.57.58):
In Reply to: Re: M idles poorly posted by Bob M on November 11, 2008 at 19:28:58:
Bob M. Timing set so the magneto trips with the pointer right on the second mark on the crankshaft pulley. With all the helpful suggestions I am going to start all over and re-check everything, especially the manifold gasket. Icing may be a problem, but the tractor is in a heated shop--70 degrees--could icing still occur? Thanks.
