Re: M idles poorly
Posted by Bob M on November 11, 2008 at 20:04:19 from (74.74.141.176):
In Reply to: Re: M idles poorly posted by Dr. Bert on November 11, 2008 at 19:42:59:
Dr Bert - At 70 degrees icing shouldn't be a problem. (Icing typically doesn't become an issue until below about 45 deg and very high humidity).
On the timing try idling the engine then loosening/turning the mag back and forth a few degrees each way to see if there's a spot where the idle improves.
