Re: M idles poorly
Posted by ChadS on November 12, 2008 at 09:16:08 from (66.228.98.41):
In Reply to: M idles poorly posted by Dr. Bert on November 11, 2008 at 17:44:56:
Take the carb bowl back off, remove the small idle stem, then take a small drill bit and run it down the passage. If it does not go all the way down, its plugged. Always lots of sediment in this area. If the throttle body is clear, then this will be the only other place to look for a clog. Hope this helps, ChadS
