M idles poorly
Posted by Dr. Bert on November 11, 2008 at 17:44:56 from (72.36.57.58):
Help. Cannot get my M to idle smoothly. New plugs- hot blue spark thru each. Totally rebuilt carburetor-all passages open, soaked in carburetor cleaner twice (overnight ea. time),fuel flow through the bowl is a steady pencil-sized stream-valves adjusted-compression test showed # three 10 pounds lower than the others. They were 110#s. At 1/3 throttle and up the engine runs very smoothly, but at an idle it runs rough and "lopes" slightly. With the idle adjustment turned out about 4 turns it runs a little better, but not well. Where do I go next? Thanks for any suggestions.
