Re: 400 hydro oil foamy???
Posted by Janicholson on November 14, 2008 at 19:21:26 from (66.173.50.27):
In Reply to: 400 hydro oil foamy??? posted by DugF on November 14, 2008 at 16:20:49:
I would put a tire Valve stem in an adapter in the Reservoir filler neck. then pump in 35psi and wait to see if it begins leaking or air is escaping. If it is, the answer might be there. If it is not, it is possibly an internal leak, allowing air to enter the suction side. Air can also enter at the pump through seals. a bad hydraulic valve will also suck air at times. Over filling sometimes helps diagnose broken O rings on the suction side. Good luck, JimN
