Posted by DugF on November 14, 2008 at 16:20:49 from (67.237.30.202):
Ok guys this might sound strange but I'm stumped!I have a Farmall 400 row crop that the hydrolics only work part time. The fluid looks normal before I start it.but after it runs only a short time the fluid looks like it has air in it. Ive cleaned the filter, drained the system by draining the reservoi and removing all of the lines to the pump ,cyl on the fast hitch and even the power steering pump. Then added high quality hydro fluid. Tehe hitch will work a couple of times and then it wont. Then Im back to the same thing, foamy fluid. If it sets a day or so the fluid will look good .Then start it and the same thing happens all over again. I cant see any leaks or anyplace where it might be sucking air. And I also bleed the system with the screw on the pump. What is going on???? Has anyone else had this same problem?? What else can I do??? Thanks Doug
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
