Re: 400 hydro oil foamy???
Posted by NEKS on November 14, 2008 at 20:29:10 from (204.183.215.78):
In Reply to: 400 hydro oil foamy??? posted by DugF on November 14, 2008 at 16:20:49:
Had same problem with my 450. Thanks to a good neighbor who know them inside and out fixed mine. Replaced gasket on left side under casting on resevoir and 0-ring on suction line, no luck. Replaced same gasket again, no luck. Removed filter screen and put pressure on suction side and used a small mirror and looked in resevior for leaks. A short pipe that should of been pressed in to casting was lose and is above oil and was sucking air. J-B welded it. This tractor could of had this problem from the day it was new. My pump always worked when oil was cold. If started it when oil was hot, it would not pick up
