You can probably see the release bearing through the access hole, see if it turns or seems loose, etc. You might try adjusting the clutch and TA, doubt if that helps -- but to fix whatever it is you have to split the tractor. New clutch kit including rebuilt clutch, pilot and release bearings are about $250 minus $24 core charge from Steel Wheel Ranch 785-548-7437. You can find the bearing locally if thats what it turns out to be.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
