Re: Another cursedly simple thing to check
Posted by gerritt in michigan on November 15, 2008 at 10:26:26 from (69.244.165.164):
In Reply to: Another cursedly simple thing to check posted by ScottyHOMEy on November 15, 2008 at 10:07:30:
+ and - are marked on back of ammeter. also tried to run a wire from the + on the battery to the F , no luck.
