Re: 300U starter solenoid
Posted by Rick Bachman on November 15, 2008 at 14:50:40 from (208.126.0.159):
In Reply to: Re: 300U starter solenoid posted by Janicholson on November 15, 2008 at 14:29:12:
Thanks! that does help. Unfortunately the copper bracket way too short. Wondering, the old solenoid is clearly marked 6v. However at some point this tractor was updated to 12v. I'm wondering if the bracket was just replaced with a wire? Or is there a chance I have the wrong solenoid?? Unfortunately Case is closed so I can't call. Thanks again for your response!
Rick Bachman
