A bracket can be made out of a heavy strip of copper (cut from a piece of copper pipe, or flattened 3/8" or 1/2" copper tubing. The copper part is important in that it needs to carry hundreds of amps. (a short O gauge cable made just long enough to loop once, and attach is OK also. The metal bracket on the Relay must be grounded to the starter frame to make it work. The 12 v relay will be fine. Hooking it's I terminal up to the ballast resistor is a good idea if you have one. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
