Thanks - Hugh Glennster
Posted by Lewis Smith on November 15, 2008 at 17:04:48 from (70.41.178.83):
Thanks to you guys for the advice on the new style starter drive. The old style would not engage at all on my Farmall 100. I cleaned up the teeth on the ring gear with a dremel tool and it now engages every time with much less impact than the old style. I would recommend anyone changing to 12 volts charging system to change the starter drive also. It is much smoother engaging the flywheel and I believe doesn't do the damage to the teeth that the old style does.
Thanks again
