Posted by Hugh MacKay on November 16, 2008 at 03:34:22 from (216.208.58.150):
In Reply to: Thanks - Hugh Glennster posted by Lewis Smith on November 15, 2008 at 17:04:48:
Lewis: I'm glad to hear that drive worked for you. I might add it should also be a priority for folks staying with 6 volt, like you say it engages more smoothly and I believe they crank easier.
It's now 16 years since I got my first new type drives. And I experienced same as you, both my SA and 130 starters came home from a rebuilder, both with new starter drives. One starter worked well on either tractor, while the other starter would not engage on either tractor. I looked them over and discovered the drives were different. I called the rebuilder, and he explained he only had one in stock, thus he got the other one from CaseIH dealer. Bring it back, I'll replace it. When I arrived he was surprised to learn it was his old type Bendix that I wanted to replace.
I'm actually quite surprised this problem still exists. The IH partsman I dealt with in 1992, actually thought I was living in the dark ages, said he hadn't sold anything but the new type in the past 20 years. That would indicate this starter drive has been around 36 years plus.
For the rest of you folks out there, go for these drives. I use my tractors a lot, have never experienced a lock starter since these were installed. The teeth on my SA ring gear were quite decent back in 92, however the 130 ring gear did not look great, however the new type drive continues to work well on the same ring gear. It works so well, I didn't bother to install a new ring gear when I did the clutch in 2002.
I may have confused some folks in the past, calling this a clutch drive. I now realize not all folks use the word clutch, although I've done a bit if checking this past week, to see what various parts guys use. Old guys like me all use clutch, younger folks are updated on "NEW TYPE", even use the parts number.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
