Just to add to the excellent responses...the primary and secondary side are inductively "coupled" so the secondary side wants to "follow" the lead from the primary side.
So..when the points open, the primary voltage goes to zero/discharge, the secondary will attempt to follow this lead, and (hopefully) the least-resistant path of discharge is thru the center plug wire, thru the distributor rotor lined up with the appropriate cylinder plug wire and jump the gap across the spark plug electrode to ground, thereby starting internal combustion of the air/fuel mixture.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
