Points...what do they do exactly
Posted by Dave Hollrah on November 15, 2008 at 10:11:24 from (207.118.218.210):
I"m working through some ignition problems on an M with a 6v coil system and just wanted to know more about the whole ignition system than just put the parts all in and adj. to the manual.
Do the open points cause the coil to charge and fire in that moment? (I can see the coil is grounded through the points when closed) And what of the gap? Why the critical nature of the point gap?
And if I may one more?
What is the purpose of the condenser?
