Posted by JanicholsonCant beat that on November 16, 2008 at 11:43:47 from (66.173.50.53):
In Reply to: head gasket leaking posted by 1938 F20 on November 16, 2008 at 08:53:36:
Well if it is running, it is in darn good shape, and all issues are small! The leak is not normal but common. Don't look too close at your other vehicles, they also leak. You can try retorquing, If it were mine, I would break each bolt loose just enough to free it, then retorque to specification, no more. Keep track of the bolt head location (mark the head to locate the rotation). if the process tightens then a bit, keep doing it. If they remain at the same turn of bolt, or less, turn them to that original mark. Do this one bolt at a time, not all at once. If it still leaks (probable) put on a new gasket and use copper coat spray on both sides of the gasket and let it get very near to dry befor assembly. (a milling of the head .050" won't hurt it either) JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
