Posted by David Goode on November 16, 2008 at 13:09:18 from (69.19.14.25):
In Reply to: Brake Pedal Shaft posted by David Goode on November 15, 2008 at 18:01:09:
I would like to thank all for the help and advice recieved. This sounds like simple fix once I can obtain a shaft that has been milled correctly. This is not the first time I have had promblems with reproduction parts. Have been working on a 8N, needed a complete engine rebuild with new valves. ONly after I put the head on after the engine was rebuilt and checked compression I noticed that it had 0 compression in one cylinder, turns out the new exaust valve was bent when I put it in. I recall it went in tougher then the others but didn't think much of it. And I also orderd a new manifold for the SM, only to find the holes were .1" to small, luckely I was able to drill them out with a drill press. What has happend to quality parts? -David
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
