Re: Farmall 130 excessive steering play.
Posted by Hugh MacKay on November 17, 2008 at 02:39:52 from (216.208.58.145):
In Reply to: Farmall 130 excessive steering play. posted by Jobe Piemme on November 16, 2008 at 15:01:14:
Jobe: Gene is right, anly way to approach this is drop the front axle, then bottom half of the steering box. You have two Woodruff keys on that vertical shaft, and I've seen them bad enough to give 1.5 turns free travel on the steering wheel.
