Farmall 130 excessive steering play.
Posted by Jobe Piemme on November 16, 2008 at 15:01:14 from (67.240.8.130):
I recently purchased a Farmall 130 and there is about a full turn of play in the steering. Both front wheel bearings are shot, but the play is prior to any tie-rod movement. I thought it would be a worn worm gear or sector, but both looked fine when I evaluated them.
I disconnected the tie-rods from the steering arm and noticed that if I turn the steering arm until it comes in contact with the gear housing base (fully cocked right or left), the steering wheel could still turn roughly a full rotation. How could this be if the worm and sector are fine, could it be one of the woodruff keys are bad? There is also a little bit of play in the steering arm, perhaps a bad bearing. If I need to disassemble the gear housing and base, how do I remove the steering arm? I tried today, but wasn"t very succesful. I removed the bottom nut but the arm wouldn"t come off the sector shaft.
Any help would be beneficial. thanks!
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
