C and SC transmission casting the same?
Posted by Slappy on November 17, 2008 at 10:26:54 from (143.88.85.90):
The lower right bolt holes on my SC transmission case are broken out. The PO had to modify the fast hitch bracket to make it work, but I would like to get it back to the original configuration.
I have a line on a "50 Farmall C transmission case and while the bolt hole pattern in the manual looks the same as the SC, I"m hoping that someone here can confirm that the two castings are interchangeable.
The part numbers are identical with exception of the suffix - the C ends in R3 and the SC ends in R33.
Any help here would be most appreciated.
