Re: 450 throttle linkage
Posted by mic560 on November 17, 2008 at 19:18:49 from (216.49.249.99):
In Reply to: 450 throttle linkage posted by colekicker on November 16, 2008 at 20:27:47:
I just fixed that on a 450 about a month ago and mine was the pin hole in the rod that the throttle lever connects to. I drove out the old pin and drilled everything out the same size then put a bolt in it so it would be easier to get out next time. If I remember correctly I used a 1/4 inch bolt.
