NAPA, this site, And many other sources can provide a positive ground B circuit regulator with three or 4 terminals. (the L terminal can be used to power the light/accessory demands, but is not much different than hooking directly to the Load side of the amp meter) The three terminal regulator has a Bat terminal (to the load side of amp gauge with #10 wire, An ARM or GEN terminal which goes to the Arm terminal on the generator (big terminal), and a Field or F terminal which attaches to the F terminal on the Gen (small terminal) Be sure the new VR has a good ground to the tractor, and that the Gen does as well. If you are using a 3 brush generator, it should have the third brush adjusted as far as it will go toward the fixed brush. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
