Re: vr and 3 position switch for h
Posted by John T on November 18, 2008 at 08:00:53 from (66.244.97.31):
In Reply to: Re: vr and 3 position switch for h posted by Janicholson on November 17, 2008 at 20:24:19:
Yo Jim, far as I know it was only Fords that used a B charging system, while most all others including Deere n IHC n Oliver n AC n MM used the A. As I know youre well aware the A system controls the charge rate by regulating the gennys field ground resistance while the B system does it on the voltage input to the Field and the Fields are already grounded on their output. To make an A system full charge you would dead ground the gennys FLD post but to full charge a B system you would apply full voltage to the gennys F terminal.........
If youre like me I get things like A or B or B or A mixed up but I learned this years ago when I tried to use a Ford VR on an IHC or Deere (I forget) and after I let the smoke out I taked to an old timer at the genny shop who yelled at me YOU CANT USE A FORD VR EXCEPT N FOR FORDS LOL
I have no idea which Fords used the B system, we would have to venture over to the Ford boards to learn that
Yall take care n keep warm now
John T
