Re: What starters and generators will work on a Farmall A
Posted by Gene Bender on November 19, 2008 at 06:05:05 from (67.55.226.167):
In Reply to: What starters and generators will work on a Farmall A posted by Jerry Deimerly on November 18, 2008 at 14:45:48:
If you are restoring and want it orogonal you need the starter for the A or B as the sw uses a pushrod to enguage. The ones for a C and later have the sw mounted at the rear and use a pull rod. You can get rebuilt ones from www.valu-bilt.com they will also have the regulator for the generator.
