Here's an easy way to check timing. Retard your mag all the way. In other words turn the points cover on the mag all the way up. Remove spark plug #1. Turn the crank until you can tell that that cylinder is on the compression stroke. It's easier if someone helps you but you can do it yourself. When the cylinder is all the way to the top, the mag should click. Remove the distributor cover and the contact block on the rotor should be very near the #1 spark plug connection. If it's not adjust accordingly. When you advance you spark timing lever, it will be at the right advance to properly run the engine. This is how I do it and it works every time.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
