Re: McCormick-Deering 10-20 trying to fire
Posted by Dave Koenigsfeld on November 20, 2008 at 05:52:47 from (148.78.54.134):
In Reply to: Re: McCormick-Deering 10-20 trying to fire posted by Mike Androvich on November 19, 2008 at 18:26:08:
Remove the distributor cover and the contact block on the rotor should be very near the #1 spark plug connection. If it's not adjust accordingly. When you advance you spark timing lever, it will be at the right advance to properly run the engine. This is how I do it and it works every time.
I get the first part. what is the contact block? is it the 'Distributor segment'? If I understand correctly, you are just adjusting the spark advance to get the motor 'timed' right. Makes life easier.
Thanks,
Dave
