Re: 40 b clutch/chatter
Posted by dave guest on November 19, 2008 at 20:56:23 from (66.19.21.92):
In Reply to: 40 b clutch/chatter posted by Scott-Tx on November 19, 2008 at 18:14:23:
If it was car I would tell you back it up to a tree and burn a little surface off the clutch, maybe oil is getting on plate. Could also be loose flywheel, weak clutch springs, clutch worn down to rivets and slipping.
