40 b clutch/chatter
Posted by Scott-Tx on November 19, 2008 at 18:14:23 from (72.190.50.251):
b has chatter when I let off clutch.When clutch is pushed down no chatter.When I let off maybe a inch or two chatter.Noise in all forward gears but not reverse.Sound is coming from under seat/PTO lever/diff. area.Where to split.Posted this q before.Thanx for responses!Just had a little bit more info.
