UUUHHHHH....
Posted by Bob on November 19, 2008 at 21:36:17 from (69.178.228.68):
In Reply to: Re: Farmall A H4 Magneto problem posted by ScottyHOMEy on November 19, 2008 at 11:56:57:
Even with the the points "open", the primary coil winding is connected between the movable (insulated) point and ground.
I can't remember the coil primary resistance "spec" offhand, but it is quite low, and will seem like a "short" unless checked with a low-Ohms setting an an Ohmmeter, even if the coil is good.
