Re: Farmall A H4 Magneto problem
Posted by ScottyHOMEy on November 19, 2008 at 11:56:57 from (71.241.193.150):
In Reply to: Re: Farmall A H4 Magneto problem posted by winds1sj on November 19, 2008 at 10:07:30:
The springy side of your points shouldn't stay grounded when the points are open. Could be a bad coil. Could also be a short in the mount of your points. You didn't mention replacing them or the condenser.
Another couple possibilities come to mind quickly.
1) The primary wire between the coil and the points is shorting to the maf body. It runs through a narrow channel and chafed or broken insulation could cause it to short. Check its condition.
2) Either one of the two (inside and outside) insulators around the ground stud of the condenser could be broken with age or from having been tightened down too hard. Look them over as well.
Either one could cause your poins to be grounding when they shouldn't.
Just to add a third idea to go with the same thought, check out the condition of the insulator that the spring side of your points mounts to.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
