Re: 40 b clutch/chatter
Posted by Gene Bender on November 20, 2008 at 03:25:18 from (67.55.226.167):
In Reply to: 40 b clutch/chatter posted by Scott-Tx on November 19, 2008 at 18:14:23:
A worn input bearing in the tranny can sure make them noisy. Clutch chatter can be caused by the three fingers not being adjusted to apply even pressure when pressure plate is enguaged.
