Re: McCormick-Deering 10-20 trying to fire
Posted by dave koenigsfeld on November 20, 2008 at 05:48:45 from (148.78.54.134):
In Reply to: Re: McCormick-Deering 10-20 trying to fire posted by spiffy1 on November 19, 2008 at 17:06:48:
Pull the cap off and the conductive area on it should match the cylinder at TDC and no valve activity (the other one should have had the exhaust open on the way up, and opening the intake soon) . After that double check, E4 I believe clockwise as you look at it, that the wires are right all the way around: 1front, 3, 4, 2 I believe.
I will check the TDC and the click of the mag. Your description of the wires does match the owners manual. Thanks, dave
