Re: Farmall A H4 Magneto problem
Posted by Bob on November 20, 2008 at 09:55:42 from (69.178.228.68):
In Reply to: Re: Farmall A H4 Magneto problem posted by winds1sj on November 19, 2008 at 13:08:27:
How many Ohms from the primary wire to the ground tab?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
