Re: Farmall A H4 Magneto problem
Posted by winds1sj on November 19, 2008 at 13:08:27 from (209.206.135.148):
In Reply to: Re: Farmall A H4 Magneto problem posted by ScottyHOMEy on November 19, 2008 at 11:56:57:
Took the coil off and everything checks out as it is supposed to. So i took the coil off and checked the primary wire to the ground and found it was grounded. so i think it is the coil. The condensor looks new and seems not to be grounding out. So i am guessing i need a new coil.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
