Re: 560 wiring diagram
Posted by CNKS on November 20, 2008 at 13:58:26 from (216.144.104.128):
In Reply to: 560 wiring diagram posted by Markabbby on November 20, 2008 at 10:54:16:
I think your tractor has a 12 volt coil running through a ballast resistor -- that's what my 460 had. I changed it to a 12 volt coil with an internal resistor. As Hugh says operator's manual has the best diagrams. There are also some rather hard to read diagrams in the parts section of www.caseih.com. Bob M's diagrams will give you the basics to get it running, but won't give detailed advice on exact wire routing, or wiring to the instrument panel, etc, as they were designed primarily for the letter series.
