Re: 560 wiring diagram
Posted by John G. Hasler on November 20, 2008 at 14:50:11 from (69.29.223.73):
In Reply to: Re: 560 wiring diagram posted by CNKS on November 20, 2008 at 13:58:26:
> I think your tractor has a 12 volt coil running
> through a ballast resistor -- that"s what my 460
> had. I changed it to a 12 volt coil with an
> internal resistor.
Not necessarily an improvement. In typical external resistor systems the ignition switch had a set of contacts that shorted out the resistor when the starter was cranking the engine. This compensated for the fact that the starter pulls the battery voltage down to about 9 volts and gave you extra spark when you needed it.
