Re: BN Fan Clutch = Stuck Motor?
Posted by billde on November 20, 2008 at 19:53:14 from (72.26.91.191):
In Reply to: BN Fan Clutch = Stuck Motor? posted by Clarkbug on November 20, 2008 at 19:41:38:
The fan hub bearing is lubricated with engine oil. It is not a clutch in any way. Even if the bearing ran dry it had nothing to do with water in the engine it is a fan bearing only.
