Re: M Farmall Napa 6v coil update...... Honda parts?
Posted by MN Scott on November 21, 2008 at 07:05:57 from (206.9.216.97):
In Reply to: Re: M Farmall Napa 6v coil update...... Honda parts? posted by Dave Hollrah on November 20, 2008 at 19:41:05:
All engines that use a 12 volt system and point ignition use a resistor in the current supply to the coil. Some use a wire in the harness some use the ceramic and some use a coil with one built in. John T explains it perfectly a couple posts up. Points open and close thousands of times a minute. With the higher pressure or amps of 12 volts they will erode or burn themselves up rapidly. That's why the resistor is used to cut the current and greatly extend the life of the points. To sum it up if you have a 6 volt system no resistor is needed, if you have a 12 volt system a resistor is required in some form or points will have a short life. 6 or 12 volts has no effect on the condenser so don't let that confuse you more.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
