Re: M Farmall Napa 6v coil update...... Honda parts?
Posted by Dave Hollrah on November 20, 2008 at 19:41:05 from (69.179.54.252):
In Reply to: Re: M Farmall Napa 6v coil update...... Honda parts? posted by CNKS on November 20, 2008 at 18:51:07:
Earlier, I had asked on this forum if the points/condenser were affected at all by an increase from 6v to 12v. The consensus there was no, so you bring up a new issue for me stating that an increase in voltage may cause condenser problems.
but this would be the only reasonable explanation for a ballast that i can think of..I mean damage to the condenser.
Anyway i do appreciate the conversation because I would like to clear up the gray areas for myself.
Thanks
