Did it freeze the block or possibly a soft plug?
Posted by chad from michigan on November 21, 2008 at 10:20:27 from (172.163.195.254):
I forogt that I had water in my Farmall A that I use for grass cutting. I had water in it because the water pump had went out of it. Yes its a 1945 A with a water pump. Someone added that and a dip stick.
Anyway it has been cold in michigan and I went out to start it up and drian it out. well after I started it up I had liquid leaking out of the clutch hand hole cover. I thought maybe it was just rain or snow. Today I took out some antifreeze and poored it in and it wasn't long it was leaking out the hand hole cover again.
Please tell me there is a freeze plug behind the fly wheel and that frooze and broke or did I mess it up and the block is cracked? It didn't freeze hard enough to freeze it in the water pump and radiator what do you think?
Chad
