Re: Did it freeze the block or possibly a soft plug?
Posted by Red Dave on November 21, 2008 at 11:40:54 from (66.216.141.163):
In Reply to: Did it freeze the block or possibly a soft plug? posted by chad from michigan on November 21, 2008 at 10:20:27:
There are two plugs behind the flywheel.
If you look at the rear of the engine, with the flywheel removed, the plug in the water passage is on the left. The one on the right is behind the rear camshaft bearing and it won't leak water, if it leaks, it would be oil.
