IH 330 hesitation problem
Posted by curtisjade1 on November 22, 2008 at 13:11:25 from (142.46.169.54):
Hi I have been restoring an IH 330 and I am having trouble getting it to run right.
It is hesitating when I give it gas and when it does get up to rpm it also hesitates when I try to put any type of load on it like putting it in gear or trying to lift anything with the loader.
I have replaced all of the wiring in the tractor switched it to a 12 volt system (replaced the alternator, ignition coil, starter, solenoid, battery, lights, ect)
I have also replaced the distributor cap, rotor, spark plugs and the plug wires.
I have also cleaned the carb and tried adjusting the only screw on the carb and tried adjusting the timing but nothing seams to be helping solve the problem.
Any help would be greatly appreciated.
This post was edited by curtisjade1 at 13:15:33 11/22/08.
