When I got my 330 running this spring I had trouble like this. If you held my carb up to the sun you could see through between the bowl and the body the gasket was all dried out and shriveled up. I showed it to the crew in the shop at the dealership and one old timer pronounced that he figured the machine had sat at least 10 years.
I put a brand new strainer bowl under my tank. The old one was plugged with corrosion. Two weeks later I was having the troubles you describe and I pulled the assembly and the entire inlet where it's threaded to go in the tank was plugged with rusty sediment. This after removing and thoroughly cleaning the gas tank.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
