field cultivator
Posted by tjiniowa on November 22, 2008 at 19:36:33 from (67.1.120.213):
How big of a field cultivator do you think I can pull with my 5288. I am in NE Iowa, pretty heavy ground, some hills on one farm I have. I am sure I can pull 24-25 ft.,, but do I dare go any bigger. I can pull a 13 knive anhyrous toolbar on the flat ground no sweat, that is about he biggest load I have had on it so far. It is bigger than it needs to be with the machinery I used to pull with my 806. I used a disc on most ground this spring, but I would like to find a field cult. to cover more ground and take less power and fuel.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
