Posted by tjiniowa on November 23, 2008 at 09:35:09 from (67.1.121.248):
In Reply to: field cultivator posted by tjiniowa on November 22, 2008 at 19:36:33:
Yes, I meant field cult. instead of discing. If it don't need to be disced then I don't want to use it. It pulls harder than a field cult. If I just need to hit some bean stubble with the cult. and plant. Discing is not needed, but it is all I have had in the past. I am going to look around for that 24-26 ft. width I belive, I got duals and fluid in the inside.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
