By all means remove the hand pump and mount in vise with bolts facing up.Measure the metal ring for width and the new seal should be about an 1/8 of an inch longer than the metal ring. When removing end cap watch for small washer between end cap and rotor, remove outer ring and seal while retaining rotating group in pump. Lube new seal with oil and install end cap,tighten evenly until you achive about 15 ftlbs rotate input shaft and torque to a final 19 ftlbs.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
