Posted by coytee on November 22, 2008 at 11:23:56 from (207.65.105.178):
We"ve got an international 886. It has power steering and today, I noticed some oil dripping from the steering box connected to the steering WHEEL. This is up in the engine compartment.
The steering box, seems to be a round, 3-part cylinder with 8 or so, bolts on the bottom, holding all three parts together.
I don"t yet have a socket thin enough to see if its loose bolts BUT...here"s my issue:
Looks like when the tractor is running and pressure is up, hydraulic fluid is just weeping from the two seams where the 3 parts are compressed together.
This could EASILY be some loose bolts on the bottom but.... I"m wondering... what if it isn"t?
What might cause oil to leak from BOTH seams on this?
Are these rebuildable (worst case scenario) or can I get gaskets and replace them (better case scenario)
Looking like I need a thinwall socket for this?
The bolt heads look to be flush with the bottom of the "cup". Meaning, the bolt heads are actually recessed a bit so I can NOT get to them very easily.
Thanks for any thoughts
I don't know if this will work but I found this on their website:
This is I think the blow up of the whole assembly and oil is seeping out of the seams between parts 26, 24 and 31 (part 23 I think either goes inside the others or doesn't exist on my tractor)
part (bolt) 27 is the part that's recessed and I can't get a socket on yet. (only had impact sockets which are thicker)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
