Re: Rod bearing wear on a 240U
Posted by Owen Aaland on November 23, 2008 at 21:15:20 from (65.165.246.117):
In Reply to: Rod bearing wear on a 240U posted by PaulW_NJ on November 23, 2008 at 21:01:09:
The copper is the bonding material between the bearing material and the steel backing. If you can see the copper the bearing is worn out.
In the 70's and early 80's there were many bearings made with nickel as the bonding material. These bearings are bad news since the nickel proved to be too hard and greatly increased crankshaft wear as the bearings became worn.
